Activity Forums Adobe After Effects Pre Rendering FX Layers?
  • Pre Rendering FX Layers?
    Posted by Andy Blondin on December 5, 2007 at 10:02 pm
    I’m trying working on a project where we have multiple artist working in AE. We only have one work station with all the trapcode code plug-ins. Is there a way to pre-render specific layers into mov’s so that we can share these files? Is this pre-rendering or Proxies?
    Darby Edelen replied 18 years, 9 months ago 2 Members · 1 Reply
  • Darby Edelen
    December 6, 2007 at 7:40 am
    You are describing pre-rendering. The pre-render commande renders a comp out at Lossless quality with Alpha and re-imports the rendered file, replacing all instances of the chosen comp with the newly rendered file.
    Proxies refers to using a stand-in for your source footage, usually because the original source footage was too large/took too long to render. The proxy is not used in final renders, only during compositing.
    You should read up on these in the AE Help (F1)
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
