Activity › Forums › Adobe After Effects › Pre-Rendering format?
  • Pre-Rendering format?
    Posted by Michael Dominic on October 20, 2017 at 12:54 pm
    My computer just can’t get through the export in Premiere a film that I have remastered.
    I need to pre-render each scene that is dynamically linked in AE.
    By default the video format for pre rendering is set to Animation. My end project will be ProRes. Should I pretender in ProRes?
    I don’t want to lose any quality and I wan’t to avoid artifacting at all costs.
    The original video is captured from DV and uprezzed to 1080, then color corrected in AE.
    Thanks.
    Michael Dominic replied 8 years, 11 months ago 2 Members · 5 Replies
  • Michael Dominic
    October 20, 2017 at 2:52 pm
    OR, is is better to render and replace in Premiere?
    I generally never have the need to pre render because the graphic work I do is generally worked on until the final export (and then often times after).
  • Michael Dominic
    October 20, 2017 at 3:45 pm
    The CC is complete. Now I just need to pre-render. Which is the best way?
  • Walter Soyka
    October 20, 2017 at 3:48 pm
    [Michael Dominic] “OR, is is better to render and replace in Premiere?”
    Yes, render and replace in Premiere.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Michael Dominic
    October 20, 2017 at 4:09 pm
    Thanks, Why is this better?
  • Michael Dominic
    October 20, 2017 at 4:57 pm
    Ah, no. I think I should explain my workflow better.
    The project started in Premier. To color correct each scene I sent them by dynamic link to after effects.
    When I try to export the entire sequence from Premier in Adobe media encoder, at some point whether it be 5 or 15 hours it hangs or crashes.
    I did a test and pre-rendered one scene in after effects and it moves much more quickly through AME.
