Activity Forums Adobe After Effects Pre- Rendering a single file
  • Pre- Rendering a single file
    Posted by Jacqueline Cheval on April 12, 2011 at 6:28 pm
    just wondering whether I can pre-render a single file, or whether I can
    only pre-render a comp.
    Seems that there is only the option of doing the latter, but maybe not?
    The only other option would be to create a proxy of a single file which I am aware of.
    thanks for any input.
    Jacqueline Cheval replied 15 years, 5 months ago 2 Members · 3 Replies
  • Dave Johnson
    April 12, 2011 at 6:39 pm
    Not sure I understand the question, but perhaps it’ll help to say that the only reason I can think of to render a single file through AE is if it’s been altered in some way within AE … the only way to alter a file in AE is inside of a comp so there’s effectively no difference between rendering that comp and rendering the altered “file”.
    Now, if you already have other files/layers in the same comp used to alter the file you want to render, you would need to pre-compose the layer that represents the file you want to render, then render that precomp. I hope that helps.
  • Jacqueline Cheval
    April 12, 2011 at 7:38 pm
    And yeah, it is for tons of effects applied to a single layer which slow down overall preview.
    Would pre-rendering help at all in this case?
    Or is it useless and a proxy would do the job?
  • Jacqueline Cheval
    April 12, 2011 at 8:48 pm
    Thanks a lot.
