Activity Forums VEGAS Pro Pre-rendered lower thirds
  • Pre-rendered lower thirds
    Posted by Jason Warfe on September 24, 2009 at 10:40 pm
    I build an animated lower third that I really like but I want to save time and pre-render it for future projects. What is the best way to go about this? I tried to pre render it before, but the black background comes along with it. Is there a way to insert a checkerboard background or something like that so Vegas knows that the background is opaque or not supposed to be there?
    Jason Warfe replied 16 years, 11 months ago 3 Members · 5 Replies
  • John Rofrano
    September 24, 2009 at 11:46 pm
    Render it alone on the timeline using the QuickTime Animation codec.
    1. Select File | Render As…
    2. Make the Save as type: QuickTime 7 (*.mov)
    3. Press the Custom… button
    4. Select the Video tab
    5. Make the Video format: Animation
    6. Change the Compression depth: to 32 bpp color
    It should look something like this:
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jason Warfe
    September 25, 2009 at 3:35 pm
    That worked! Thanks. I purchased the Vegas Pro production assistant and I like it. I made some adjustments to the lower thirds and wanted to save on render time. This will help a lot!
  • Jason Warfe
    September 25, 2009 at 4:06 pm
    Wait…I thought it worked but it didn’t. The lower third still has a solid black background. I followed the instructions exactly but it’s not working. I am not sure what I am doing wrong.
  • Terry Esslinger
    September 25, 2009 at 4:21 pm
    Have you ‘turned on’ the alpha channel. Right click the event and go to media.
  • Jason Warfe
    September 25, 2009 at 6:16 pm
    That is what I did wrong. It works now, thanks!
