Pre-render problem
Recently I start working with templates and when I pre-render third party plug-ins (particular, form, optical flares, etc.), After Effects popup error “After Effects error: Error (4) reading frame from file C:\ name of the file.” (86::2) and After Effects crash. Its only happening when I use quick time-jpeg2000, works fine with quick time-mpeg4 but the quality is poor. Using CS4 version.
Thank you
