Activity › Forums › Adobe After Effects › Pre render mov replaces Composition
Posted by Fabienne De vries on October 19, 2017 at 9:33 amHi,
whenever I pre-render a composition, After Effects automatically replaces the composition with that mov. Why is it doing that and how can I turn it off because I don’t like it 🙂Walter Soyka replied 5 years, 9 months ago 3 Members · 3 Replies -
Walter Soyka
October 19, 2017 at 1:54 pm[fabienne de vries] “whenever I pre-render a composition, After Effects automatically replaces the composition with that mov. Why is it doing that and how can I turn it off because I don’t like it :)”
That’s exactly what pre-rendering [link] does — it renders a composition and replaces its usage with the rendered output.
What are you trying to do? Perhaps you’d rather use a proxy [link] workflow? Although most folks think of proxies as low-resolution or low-quality versions of a comp, there’s nothing to stop you from using high-quality renders as proxies to speed up your work.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Juan Martínez
November 30, 2020 at 4:19 pmHi Fabienne, just like you I don’t like that replacement of the Prerenders also, fortunately Adobe team has an option for people like you and me so what I do is this:
1. Go to > Composition > Pre Render
2. In the render queque select the option “Post Render Action” and choose the want you prefer, I personally use only the import One.
Walter Soyka
December 2, 2020 at 4:01 pmThat’s a good tip, Juan!
In case it helps, you don’t need to choose “Pre-render” to get access to the “Import” post-render action. You can do that with any item added to the render queue, and you can even make your own output module with the post-render action set to import (or even set it as the part of the default output module if you do this all the time).
