Activity Forums Adobe After Effects Pre Render Issues
  • Pre Render Issues
    Posted by Ricardo Jurado on February 22, 2023 at 5:55 pm
    Hi!
    I’ve been working on this project for some weeks now on my personal computer because at work they refuse to give us the equipment we need to work but rent’s due so I’m left with no other option than to use mine…….Point is…just today this started showing up all over the preview screen in specific parts of the animation. Always on the same parts.
    I can get rid of them if I turn off certain layers but those layers have elements I need in the final render.
    Any clues about what it could be?
    I’m not a hardware specialist but looks like maybe the graphics card(?).
    I hope it’s not hardware related though…
    Mads Nybo jørgensen replied 3 years, 6 months ago 2 Members · 1 Reply
    February 23, 2023 at 5:04 pm
    Hey Ricardo,
    Have you rendered out a test file?
    If they appear on that, it is likely to be those layers.
    In which case you’ll need to look at them individually for stray key-frames, or maybe a plugin that are not registered/subscribed to.
    If they don’t appear on the render out, then it is your software/workstation that is unhappy – could be an upgrade gone wrong, or too heavy a lift. If you are able to ignore the problem, finish the job. Otherwise you’ll need to either fix your system, or find a new one.
