Activity Forums Adobe After Effects Pre-flighting render items. Render items to check: 1
  • Pre-flighting render items. Render items to check: 1
    Posted by Chris Orcfilm on February 13, 2015 at 4:56 am
    So, using CC 2014, latest update on Windows 8.1 pro, have one item in the comp, a R3D file. I’ve applied a keying effect to it.
    Now I want to render it to a DPX 10 bit sequence with alpha.
    Hit render, and the render button does not change from blue and the status displays “Pre-flighting render items. Render items to check: 1” then the status eventually goes blank. Nothing happens.
    I’m posting this because I finally figured it out, in case you run into the same thing.
    Seems because I used a period in the render subfolder’s name, the above occurred. Changed the period to an underscore and it started rendering no problem. You can have any number of periods in the filename, just not the folder name, at least not like a folder named “A014_C008_0101X1_001.R3D”
    Hope this saves someone else some time.
    Orchard Film Studios, Canada
    Chris Orcfilm replied 11 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
