Pre-encoded assets and Compressor Job Actions
Hi Guys-
Just a quick question that I can’t quite figure out:The scenario: Compressor has created your BluRay disc (using the Create BluRay job action) and has encoded the AV perfectly, but you see an error in the Compressor built Menu; spelling mistake, wrong BG image etc.
Is there any way to use your prefect pre-encoded AV streams and just use Compressor to create the new Menus and burn to BD-R? Using the job action, doesn’t leave you with any saved AV streams to re-use. I’ve tried importing the AV streams back into Compressor from a previously created elementary stream but Compressor is having none of it!
All I can seem to do is to start from the original QT master and endure another 6 hour encode just to fix a problem with the menu, which ultimately has nothing to do with the encoding of the AV master.Any suggestions?
Cheers,Simon
“Is it me or do I spend half my life watching little grey bars turn into little blue bars??”
