Activity › Forums › Adobe Premiere Pro › pre-cut central 2sec of all clips and add to sequence
  • pre-cut central 2sec of all clips and add to sequence
    Posted by George Kalogeris on October 13, 2017 at 10:58 am
    I have tons of clips and I want to use only 2 sec of each one in the timeline.
    Then I ‘m going to search inside each one with Slip Tool to find the desired scenes
    Is it possible ?
    George Kalogeris replied 8 years, 11 months ago 2 Members · 3 Replies
  • Tero Ahlfors
    October 13, 2017 at 11:01 am
    Yes but it would be probably more efficient if you searched your two second clips in the source monitor from the original clips and added them to the sequence.
  • George Kalogeris
    October 13, 2017 at 11:15 am
    Clips all OK but they need trimming to discard the start/end because of motion due to button press.
    How do I batch trim (crop?) them?
  • George Kalogeris
    October 13, 2017 at 5:39 pm
    Exactly, the clips need automatic trimming, they are over 1000.
    I need something like “automate to sequence, with 5sec overlapping” so the usable clip in the timeline is trimmed in both ends
