Activity Forums DaVinci Resolve Pre-conform in Davinci Resolve
  • Pre-conform in Davinci Resolve
    Posted by Ronald Ruiz on July 31, 2013 at 11:04 am
    Hi, I know this subject has been part of many threads but after reading all of that I cant get this to work. Maybe is a concepts Misinterpretation so here it is what I know:
    Make a flat video: I rendered the edited video from Premiere
    Make an EDL: I exported EDL from Premiere (CS6 and this was an interesting subject because when the EDL where readed on Davinci it closed up, I found out that the problem was the drop frame)
    and then pre-conform in davinci: The flat video had the right amount and size of cuts but no video on them (it didnt found the “sources”).
    Do you think that the problem was that I exported DPX files? (I did this because the reading of mov files in davinci was horrible, really bad quality for DVCPRO 50)
    Thats it. Sorry for my english by the way
    James Brill replied 13 years ago 2 Members · 1 Reply
  • James Brill
    August 10, 2013 at 3:27 pm
    Not sure if you figured this out but make sure in the conform settings tab that the “assist using” button is NOT selected.
