Pre comps not changing independently?
I’m a bit of a nooby and have the following problem.
I have 8 pre comps.
Inside each comp is an image and some accompanying text.
The first pre comp is called “Image 1”. The text says “message 1” and so pre comp 1 will contain an image and “message 1”.
The 2nd pre comp is a replica to the first except it contains a mask in the middle of the image to give the overall and combined effect a boost, this pre comp is called “image1mask”.
The 3rd pre comp however, is called “image 2” and is a separate image and says “message 2”
I have repeated the steps above until the 8th pre comp, which contains the 4th image and the mask for “image 4” pre comp.
The problem is this:
I want to replicate pre comps “image 1” & “image1mask” so i dont have to recreate them all over again.
I want to be able to call these pre comps “image 5” & “image5mask” respectively.
When I change ANYTHING in the “image 5” & “image5mask” pre comps however, it updates those changes to “image1” & “image1mask”.
How do i uncouple these?
All i did was duplicate the first 2 comps and then rename them to image 5 etc.
Thx in advance
