Activity Forums Adobe After Effects pre-comps and transfer modes
  • pre-comps and transfer modes
    Posted by Mark Wilkinson on September 26, 2005 at 11:55 pm
    i have two layers that i want to push down into a pre-comp so i can play with a mask over them. when i make the pre-comp i lose my transfer modes ( one layer is Add the other is Multiply ). the pre-comped layer goes to “normal” and doesnt reflect the modes in the underlying layers. changing the mode of the pre-comp layer itself just looks messy. any way of working through this ?
    Aharon Rabinowitz replied 21 years ago 2 Members · 1 Reply
  • Aharon Rabinowitz
    September 27, 2005 at 2:31 am
    If you colapse transformations on that nested comp, it should make the layers in the precomp use their original transfer mode in your main comp. However, it does cause other problems so keep your eye out for trouble with those layers.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
