Activity Forums Adobe After Effects Expressions Pre-composed Expression
  • Pre-composed Expression
    Posted by Luke Regan on October 26, 2009 at 10:47 pm
    This has been driving me crazy for a few days and I feel like it is something very simple that I just can’t seem to find the answer too. I have rotating wheels on a bicycle and I used the expression below on the rotation property in order to have the wheels repeat their rotation for a certain duration and then stop. Works great, but the layer this happens on is in a pre-composed comp which is nest in the main comp. Trying to be organized except when I switch to the main comp the wheels do not stop rotating like they do in the nested comp. I’m guessing that I need to link the main comp with the layer somehow or vice versus so that the main comp can recognize the layer with the expression?
    if(time < 17.9){ loopOut("cycle")} else(rotation)
    Luke Regan replied 16 years, 11 months ago 3 Members · 3 Replies
  • Dan Ebberts
    October 26, 2009 at 11:03 pm
    I’m not seeing that behavior (CS4). It stops in the main comp as well.
    Dan
  • Xinlai Ni
    October 26, 2009 at 11:13 pm
    Are you using time remapping or shift of precomp layer on the timeline panel for the main comp?
    Xinlai Ni
    Software Engineer, Google Inc.
  • Luke Regan
    October 27, 2009 at 1:59 am
    Thanks for responding,
    I’m not using time remapping or the shift of precomp layer. The Expression I used for the rotation is meant to stop at 17.9 seconds on the layer which it does in my project but when I switch out of the pre-comp into the main comp it doesn’t stop rotating the wheel at 17.9 seconds, it just continues to repeat.
