Activity Forums Adobe After Effects Pre-Compose causes blurry objects
  • Pre-Compose causes blurry objects
    Posted by Luke Allcock on January 31, 2011 at 8:18 pm
    So i’m doing some typography to music. When i’m lining up the words to the music and sorting out the spacin and such i have each word on a seperate layer. The idea is then to pre-compose these layers into one to tidy up the timeline. However when i do i get blurry text, before i pre-compose all is fine, any ideas?
    Spencer Tweed replied 15 years, 7 months ago 2 Members · 3 Replies
  • Spencer Tweed
    January 31, 2011 at 8:33 pm
    Yeah – there is a switch called “collapse transformations”. It looks like this * and is between the quality switch (like this: /) and the shy-guy switch on the layer. When you hit that switch AE will no longer treat the precomp as one footage item, but will actually go in and render it as if it were not precomposed.
    – Spencer
  • Luke Allcock
    January 31, 2011 at 8:35 pm
    Ha, simple as that! Thanks alot for the quick reply, its worked a treat.
  • Spencer Tweed
    January 31, 2011 at 9:14 pm
    No problem!
    – Spencer
