Activity Forums Adobe After Effects Pre-comping SHINE?
  • Pre-comping SHINE?
    Posted by Jimmy Brunger on May 10, 2007 at 1:46 pm
    Hi all,
    I’ve got a problem whereby I have a text layer with shine applied to it that I need to pre-comp with a bunch of other related layers into my main comp…the shine effect gets cut off when I move the pre-comp around in my main comp – the edges of the precomp are cut off sharp. Continual rasterize doesn’t really work because shine then tries to re-calculate it’s point of origin and messes up.
    Any thoughts how I can get around this?
    My quick fix is to put a soft edge mask around the offending layers, but it’s far from ideal.
    Any thoughts appreciated.
    *Production Studio Premium / *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
    Steve Morris replied 19 years, 4 months ago 5 Members · 5 Replies
  • Mike Procunier
    May 10, 2007 at 2:04 pm
    I’d make your pre-comp size large enough so that it’s edges don’t appear on screen as it moves?
  • Steve76
    May 10, 2007 at 2:07 pm
    That’s what I’ve done in the past aswell. Crank up the Pre-Comp size so you don’t get the cut off. Works fine for me.
    cheers
    steve
  • Jeff Dobrow
    May 10, 2007 at 2:16 pm
    ‘Grow Bounds’ should handle this perfectly.
  • Jimmy Brunger
    May 10, 2007 at 2:48 pm
    I am such a fool – Of course! Thanks guys..think I need a coffee and a talking to..
  • Steve Morris
    May 10, 2007 at 4:00 pm
    You may need to move GROW BOUNDS up in the rendering order after you add it, for it to work.
