Activity Forums Adobe After Effects pre-comping problem
  • pre-comping problem
    Posted by Simon Edwards on April 10, 2009 at 5:14 pm
    Hi guys,
    Wondered if anyone can help me with a problem I’ve encountered while pre-comping.
    I created some little characters then animated them and rendered it off. I then pre-comped these onto a background in after effects and this worked fine. I rendered a test off (the first link) and it looked ok so I carried on but then on my next render (second link) the characters stopped moving and just glide. when I open the project in after effets sometimes the characters move for a couple of frames then all just glide again. I have no idea why this is happening, the project and the pre comps all have the same frame rate. Any help would be great, thanks!
    https://www.youtube.com/watch?v=aDVw_RfpKck
    https://www.youtube.com/watch?v=wSKIGXJf_m4
    Simon Edwards replied 17 years, 5 months ago 2 Members · 2 Replies
  • Darby Edelen
    April 10, 2009 at 7:19 pm
    How are you controlling the animation of the characters’ legs, etc?
    Darby Edelen
  • Simon Edwards
    April 10, 2009 at 7:49 pm
    its just two seperate pictures which i put one at 100% opacity and the other at 0% then on the next frame swapped them around. I then rendered this off and put it over the background in a new comp and looped the footage then changed the scale and position to try and make it look like the are moving throughout the picture
