Activity Forums Adobe After Effects Pre-comping Auto Orient 3D layers
  • Pre-comping Auto Orient 3D layers
    Posted by Joe Vac on February 27, 2007 at 8:27 pm
    I basically have a comp with several 3D layers all auto oriented toward camera – my problem is that when I pre-comp these layers and rasterize the comp the layers no longer auto orient toward my camera… (which they should)
    i went through and pre-comped less layers than needed to single out layers several times and it still does it
    there are no 2D layers in between 3D layers
    I have a null as one of the layers but nothing is attached to it
    within the pre-comp auto orient is still on.
    my camera is controlled by an “x” null and a “y” null both in 3D
    Any info would be great – deadline looming
    Mylenium replied 19 years, 6 months ago 3 Members · 2 Replies
  • Julio Crespo
    February 27, 2007 at 10:43 pm
    try collapse transformations
  • Mylenium
    February 28, 2007 at 7:20 am
    [JoeV]
    I basically have a comp with several 3D layers all auto oriented toward camera – my problem is that when I pre-comp these layers and rasterize the comp the layers no longer auto orient toward my camera… (which they should)”
    No, they shouldn’t. If you use continuous rasterize/ collapse transformations, the camera in the pre-comp becomes irrelevant and only the camera of the topmost comp is used. The behavior is correct. If you need the auto orient, use expressions. Apply a simple lookAt(position,thisComp.layer(“Camera”).position) to the orientation property of each layer.
    Mylenium
    [Pour Myl
