Activity Forums Adobe Premiere Pro Pre Comp in PP2.0?
  • Pre Comp in PP2.0?
    Posted by Tony Bartolucci on May 8, 2006 at 9:55 pm
    Is there a way to precompose my footage that I have in Premiere Pro 2.0 as you can in AE?
    I have so many little clips that each have there own effects on them, that I’m starting to get confused, so If I could “pre-comp” what I have so far that would help?
    Steven L. gotz replied 20 years, 4 months ago 3 Members · 3 Replies
  • Steven L. gotz
    May 8, 2006 at 10:10 pm
    You can put it all into a new sequence, then export an AVI from the new sequence. Replace the original material in the main sequence with an AVI created from the new sequence. If you need to change it later, just make the change and export again.
    It isn’t the best solution, just the easiest way to get around memory issues.
    Steven
    https://www.stevengotz.com
  • Ken Adolph
    May 9, 2006 at 2:19 am
    why not a nested sequence intead of an avi?
    Ken Adolph
    Media Group
    Editor/Post Supervisor
    https://www.mg.ca
  • Steven L. gotz
    May 9, 2006 at 2:21 pm
    Ken is correct. I had just answered a question regarding memory issues and it carried over. Sorry about that. Just put a selection of clips into a new sequence and nest the sequence.
    Steven
