Activity › Forums › Adobe After Effects › Pre-comp doesn’t show properly in the timeline
  • Pre-comp doesn’t show properly in the timeline
    Posted by Blahtor Magnus on February 18, 2009 at 11:14 pm
    I made a 3D object that is just several flat planes put together to form a box.
    All the planes are put in a pre-comp for ease.
    The pre-comp with the 3D object is set to have the same time length as the main comp but the 3D object only shows in the first seconds on the timeline.
    Why?
    Blahtor Magnus replied 17 years, 7 months ago 2 Members · 3 Replies
  • Blahtor Magnus
    February 18, 2009 at 11:18 pm
    Problem solved.
  • David Johnson
    February 19, 2009 at 12:10 pm
    Are you sure the layers inside the precomp don’t end after a few seconds and that the precomp layer in your main comp isn’t obscured by another 3D layer?
  • Blahtor Magnus
    February 19, 2009 at 5:11 pm
    This was the reason, yes.
