Activity Forums Zaxwerks prbably simple
  • prbably simple
    Posted by Arty Gold on May 17, 2006 at 6:42 pm
    trying to import a file from illustrator
    it’s a logo
    figured out how to save it so that the logo actually will import…
    now it imports with an entire box around it…
    which i’m assuming is the background that illustrator thinks is part of the logo?
    how can i stop that ?
    thanks in advance
    Arty Gold replied 20 years, 3 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    May 18, 2006 at 12:10 am
    Hi Arty,
    You’re probably right about the box being behind the logo in Illustrator. People sometimes add a background for a variety of purposes.
    It may be white on white and hard to see. The fastest way to find out for sure may be to switch the view to outline mode and see if you can find the box outline. It may also be locked, but you can unlock it using Object>unlock all, then delete it.
    Does this help?
    Jon
  • Arty Gold
    May 18, 2006 at 3:14 pm
    two things i learned.,,
    first your suggestion did help !
    second you have to unclick that compression box before you save it…
    could there be anymore annoying little steps ! yes i’m sure there are…ha
    thanks for the help !
