Activity › Forums › Adobe Premiere Pro › Pr CS4.0 vs CS4.2 render quality got worse or… ???
  • Pr CS4.0 vs CS4.2 render quality got worse or… ???
    Posted by Peter Kolarski on November 28, 2009 at 6:07 pm
    Hi everyone,
    I just found an issue with the newest patch for CS4. I alraedy tried to ask this on Adobe Forum – no luck and this forum helped me in the past few times so i hope this time as well 🙂
    I was doing some project, the source file was HDV but i had to export it to DV so i did. Used Pr4.0, scaled the files down, rendered with Microsoft AVI / PAL DV and it was great.
    Next I installed the 4.2 update, loaded same project – wanted to see if the render will be any faster etc. I didn’t see any difference BUT…
    The quality of the *.avi file is now lower then it was on the 4.0 !!! It’s like less sharp/clear then it was. It’s especially visible on the text (using Premiere inbuilt Titler). On the 4.0 was clear and sharp now is little blurry. Now it looks like the camera was a bit out of focus ! How is that possible ???
    (using just Pr, no matrox or custom plugins)
    specs:
    Win 7 x64 // 4GB // GF260 GTX // GA-P55-UD4
    I also tried using option “render at maximum quality” but it just makes it even worse (especially for the text)
    Pls help :/
    Peter Kolarski replied 16 years, 10 months ago 4 Members · 11 Replies
  • 11 Replies
  • Tim Kolb
    November 28, 2009 at 8:48 pm
    Have you verified that all the settings for the encode were identical? I wonder if the update ended up flipping a proverbial switch someplace?
    TimK,
    Director, Consultant
    Kolb Productions,
  • Ann Bens
    November 28, 2009 at 10:30 pm
    I still do not like Premiere’s scaling down hdv to sd but 4.2 is definitely better than 4.0 or 4.1.
    Did you turn on Maximum Render Quality in the export settings?
  • Peter Kolarski
    November 28, 2009 at 10:53 pm
    Yes, I did try the “use maximum render quality”. The picture was a bit better , but for my taste a bit oversharped – like in Photoshop when you do sharpen to many times) but the text from the titler was a complete failure on this setting.
    Plus when You do AVI PAL/NTSC you cannot change things in settings, just fields.
    This is weird, 4.2 shouldn’t change anything but it did.
    I know that Pr has problems with HDV/DV conversion but i was ok with 4.0 and now it’s……
    And now I have to projects coming and both will need similar procedure and I don’t want to go back to 4.0 but I’m afraid I will have to :/
  • Tim Kolb
    November 29, 2009 at 2:59 am
    Did anything weird happen to the pixel aspect values anywhere in any of the project or encode settings?
    TimK,
    Kolb Productions,
  • Peter Kolarski
    November 30, 2009 at 2:20 pm
    No, pixel aspect is the same all settings are the same but the output qulity is worse :/
  • Tim Kolb
    November 30, 2009 at 3:48 pm
    Odd.
    Are you using an existing ME job queue?
    Does it appear that interlacing is messed up? …or is it overall just soft? The aspect ratio of the image is still visibly correct?
    TimK,
    Kolb Productions,
  • Slobodan Milivojevic
    December 4, 2009 at 9:51 am
    Hi!
    I think that your problem is that U haven’t updated MEdia Encoder to version 4.2, whitch solves this problems with bad rendering output.
    I have that problems also with output from Premiere!
    Cheers!
  • Peter Kolarski
    December 4, 2009 at 4:34 pm
    No, i did update to both Pr and AME to 4.2 so its not that :/
    December 5, 2009 at 8:11 am
    Well,
    lets try few things:
    1. If your material is upper field, export it as upper filed, because if U put progressive, your material will be deinterlaced, so it will use some quality.
    2. Can U try to use UNCOMPRRESSED AVI, just to see is it maybe DV artefacts, because on RED color in DV U will have very jagged edges? IS your text RED?
    3. Finally, open DV 16:9 sequence, not HDV. PLace clips in timeline, right click on clips ant put SCALE TO FRAME SIZE. THen try to export and see if there is some difference.
    I hope this may help U…….My expiriance is that in 4.2 updates, outputs are just great!
  • Peter Kolarski
    December 6, 2009 at 10:10 pm
    The files I’m working with are:
    Type: MPEG Movie
    File Size: 3,6 GB
    Image Size: 1440 x 1080
    Pixel Depth: 32
    Frame Rate: 25,00
    Source Audio Format: 48000 Hz – compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Total Duration: 00:19:52:12
    Average Data Rate: 3,1 MB / second
    Pixel Aspect Ratio: 1,3333
    What i did – opened new DV 4:3 comp. Scale down to match the window size (yes with black “frames” on top and bottom of the screen like dvd things. It should have them.)
    Render to PAL DV 4:3 LOWER FIELDS.
