Activity › Forums › Adobe Premiere Pro › Pr CS 5.5 not playing timeline or clips
  • Pr CS 5.5 not playing timeline or clips
    Posted by Michael Krupnick on March 20, 2013 at 10:17 pm
    Yesterday, everything was fine. Today, the project loads, but the sequence or clips don’t play at all. I’ve tried trashing plists, media caches, copying/pasting into fresh sequence … no dice. Checked media disc by loading FCP project, and that’s okay. Using a MacPro 8-core running Lion. Media on GTech. DVCProHD 72024 files. Looks like the app itself is unresponsive, since this project isn’t the only one with a dead timeline. What to do?
    MaK
    Michael Krupnick replied 13 years, 5 months ago 3 Members · 6 Replies
  • Tim Kolb
    March 22, 2013 at 2:18 am
    I wonder if trashing the preferences might help?
    It definitely sounds as if the application has become a bit wonky based on what you’re saying you’ve done to troubleshoot.
    Re-installing just Premiere Pro may be something you want to try if that doesn’t work.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Kevin Monahan
    March 23, 2013 at 12:08 am
    Sounds familiar. See if the info in this article helps: https://helpx.adobe.com/premiere-pro/kb/playback-stops-loops-soundbooth-premiere.html
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Michael Krupnick
    March 23, 2013 at 12:23 am
    No, Kevin. What happens is Pr launches but won’t play a sequence or clip. At all. I can scrub and see the video, but there is no audio. I’ve uninstalled and reinstalled from disc, in addition to the earlier measures above. This renders Pr useless as an NLE. And before it comes up, I don’t have the funds for CS6; I just want to run the one I’ve already paid for.
  • Kevin Monahan
    March 23, 2013 at 1:21 am
    Since you’ve uninstalled and reinstalled, and your clips are a standard codec, I would suspect your media drive. Can you copy some of the clips to a different hard drive and see how Premiere Pro behaves?
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • Michael Krupnick
    March 23, 2013 at 1:37 am
    Sorry, Kevin; again, nope. I mentioned in the first post that I’d loaded an FCP project from the same drive with no issue. Not the media drive, it’s Pr for sure. This is a dual-boot 8-core MP, and FCP is on Snow Leopard, while Pr is on a separate Lion disc. Adobe Ps CS5 runs fine on both OSs.
  • Michael Krupnick
    April 4, 2013 at 7:34 pm
    Apparently this is a fairly common issue on Intel Macs equipped with Harmon-Kardon Soundsticks I audio monitors. The speakers work fine on all other apps. But it appears PrCS5.5 has some sort of USB driver conflict with the monitors (which are connected via USB), especially under OS10.7. In my case, it occurred on every launch of Pr. HK makes no new drivers for the first generation of their SS product. It seems there is some latch in Pr preferences that is not reset but the issue can be temporarily remedied by manually resetting the AUDIO HARDWARE parameter to BUILT-IN OUTPUT (Apple default). The timeline resumes activity, playing audio through the tinny Mac speaker. I was able to manually toggle the hardware back to SS and get full function back for the duration of the session. I have to do this quick reset upon a new launch after quitting Pr. Try this before going through the laborious and possibly futile routine of reinstalling PR or the OS.
    MaK
