Activity Forums Adobe Premiere Pro Pr CC track assignment erratic behaviour
  • Pr CC track assignment erratic behaviour
    Posted by Morten on June 29, 2013 at 8:51 pm
    I think I have discovered a major bug in the new Premiere.
    Added a new 5.1 audio track, and suddenly this becomes default source for audio inserts, which I cannot change. Only when I create a new 5.1 audio track, can I select this as a new source. And if I delete the track with the “A1” audio insert patching, the “A1 indicator” disappears with the deleted track!
    Also when I insert an audio clip it sticks on the 5.1 track, and cannot be moved to a normal audio track, and even can cause Pr to crash!
    Have tried to trash the preferences, but this does not solve my problem!
    – No Parking Production –
    2 x Finalcut Studio3, 2 x Prod. bundle CS6, 2 x MacPro, 2 x ioHD, Ethernet File Server w. X-Raid…. and FCPX on trial
    Morten replied 12 years, 10 months ago 3 Members · 4 Replies
  • Muthu Ayyeppen
    June 30, 2013 at 12:22 pm
    Hi there,
    Seems like in your General Settings/Audio – you have selected all incoming sources as 5.1 which turns all your Stereo Tracks into 5.1 while on import so it can only get into a 5.1 track and not a Standard track in the timeline. Try amending that settings to “Use File” , then reimport your audio tracks and see if it solves.
    Best,
    Muthu
  • Morten
    June 30, 2013 at 12:59 pm
    I already checked this setting, and it is set to “use file”.
    No, there is something else wrong, and I get the program to crash just by trying to move an audio clip between different tracks!
  • Peter Garaway
    July 1, 2013 at 9:09 pm
    Can you do a screen recording have your exact steps? Also, it would be helpful to see your crash log. You can send it to me via PM.
    Peter Garaway
    Adobe
    Premiere Pro
  • Morten
    July 3, 2013 at 11:12 am
    Tried to duplicate the episode, but could not get Pr to behave bad.
    Maybe it is because I have trashed the Prefs, and copied everything into a new project.
    Anyway it all works as it should now : )
