PR – BCC 4.1 for Intel-based Macs Now Available
Posted by Janice Dolan on November 2, 2006 at 10:04 pmHi – this announcement went out today.
Boris FX Releases Boris Continuum Complete for Intel
Walter Biscardi replied 19 years, 10 months ago 4 Members · 6 Replies -
Christopher Wright
November 4, 2006 at 4:36 amUnfortunately it is still not working in FCP, as all effects now say they don’t have “proper authorization” when booting up FCP. Even though they work fine in Red 4!
Tim Langston
November 9, 2006 at 1:07 pmAny word on this? Is it working with the Intel Macs?
TimTim Langston
Cryin’ Out Loud Productions
Fort Wayne, IN
http://www.colproductions.com -
Walter Biscardi
November 10, 2006 at 8:54 pm[Tim Langston] “ny word on this? Is it working with the Intel Macs?”
I had to remove this from my FCP system. First the system crashed 5 times during normal operation in about 2 hours. Then the system crashed every single time I tried to render anything, and nothing had the BCC filters applied yet.
I removed the BCC4 plugins and now the system is working well again. No idea what’s going on and I even purchased the update so I could use them in an Intel based project, but they are causing havoc over here.
Mac Pro Quad 3.0, FCP 5.1.2, AJA Kona 3, QT 7.1.3
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Tim Langston
November 10, 2006 at 9:48 pmThanks for the heads up. I just finished a huge project, come Monday I was going to try and install. I think I’ll wait.
Tim
Hey Peter, what’s up with 4.1???
Tim Langston
Fort Wayne, IN
Walter Biscardi
November 10, 2006 at 10:11 pmAs a follow up, the BCC 4 does seem to be working in After Effects 7.0 on the same machine. So if you can use them in AE, you’re ok and in my case, I can simply export the scenes from FCP and just use the filters in AE.
Walter Biscardi
November 10, 2006 at 10:14 pm[walter biscardi] “As a follow up, the BCC 4 does seem to be working in After Effects 7.0 on the same machine. So if you can use them in AE, you’re ok and in my case, I can simply export the scenes from FCP and just use the filters in AE.”
Ok, nevermind. AE just locked up during a second test render. Ok, BCC 4 is not ready for prime time yet on the Intel Macs.
