Activity Forums Adobe Premiere Pro PproCS5 – Chroma up to 120, and down to -20, is this a problem? How to correct if so?
  • PproCS5 – Chroma up to 120, and down to -20, is this a problem? How to correct if so?
    Posted by Aza Allen on September 14, 2011 at 11:20 pm
    I am in Premiere CS5 and working with Graphics that I created in AE CS5.
    In Premiere, I put the levels effect on the clip and it adjusted the Luma to the correct standards, but the Chroma is way out of the range – will this be a problem?
    My Final output is going to be DVD.
    If this is a problem, what is the best way to correct the Chroma?
    Thanks all!
    Oh, BTW – it’s within the legal limits on the Vectorscope in Premiere.
    My portfolio can be seen at http://www.ruesterprod.com
    My personal website is http://www.azaallen.com
    Jon Barrie replied 14 years, 12 months ago 3 Members · 3 Replies
  • Ben G unguren
    September 15, 2011 at 12:57 am
    If your colors are too rich, the MPEG encoding for the DVD won’t look good. In my experience, this is especially the case with reds, blues, and purples. At any rate, all you need to do is drop the saturation and it should be fine.
    But you seem to know your stuff, and that seems pretty obvious… are you looking for a more involved solution?
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Aza Allen
    September 15, 2011 at 1:48 am
    I do know a bit, but it’s a very uneven distribution of knowledge 😉
    I played a bit with the Saturation, and that helped some, but does it need to stay completely within the 0-100 IRE levels on my waveform? For DVD, what is the best “safe zone” for chroma? (I know Luma needs to stay pretty tight to avoid the buzzing, and overblown highlights, etc. – but not as familiar with the Chroma levels)
    and What tool/effect would best help in dealing with chroma levels? (As I stated previously, I used the Levels effect to help clean up the Luma values)
  • Jon Barrie
    September 15, 2011 at 4:25 am
    Try Broadcast Colours and tinker with the settings there. make sure you set it to the Region format you are going out to. i usually add it to a nest of the final edit in an “export” seq that way is blankets across the whole edit in one hit instead of adding it to every clip instance.
    ie: PAL or NTSC
    You can set one up as the Luma safe limiter and another one to handle the chroma level limiter.
    – JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
