Activity Forums Adobe Premiere Pro PProCS3 + Media Encoder = DISASTER
  • PProCS3 + Media Encoder = DISASTER
    Posted by Jordan Orberg on October 25, 2007 at 4:05 am
    Hello Everybody,
    So I had to reinstall my CS3 master suite because some weird glitch wouldn’t let me load some of the programs unless I opened them in a certain order. I contacted Adobe about this and they basically said to reinstall. So now that I’ve reinstalled, my freaking Media Encoder inside Premiere Pro CS3 won’t work. I finish my movie, and then go to export using the Media Encoder. Instead of loading, Premiere Pro CS3 just hangs up and won’t shut down. It freaking sucks!!!
    I’m really upset right now over this whole thing. I really don’t want to call adobe again and sit on the phone waiting on someone to simply tell me to reinstall their bug-ridden product. Does anybody know of a solution to this problem? I’ve searched around on Google, but couldn’t find anything.
    I appreciate any help you can give me.
    -Jordan
    Eric Addison replied 18 years, 10 months ago 5 Members · 9 Replies
  • 9 Replies
  • Blast1
    October 25, 2007 at 9:40 am
    I would surface check the disk with the OS and Apps, and do a comprehensive memory check, to eliminate any hardware problems, you didn’t mention if you did a total system reinstall? or what other stuff you are running on the computer
  • Jordan Orberg
    October 25, 2007 at 12:26 pm
    I’m pretty sure I did a complete system install — I had to re-enter my serial number and everything.
    Also, I checked my hard disks for errors and came up with nothing. I also ran memtest and another utility and everything came up fine. Here are my system specs just in case this will help:
    Windows XP – SP2
    Intel Core Quad – Q6600
    eVga 680i MB
    4 x 1024 DDR2-800
    2 x Seagate Barracuda 500gig HD
    1 x WD Raptor 160gig HD
    Thermaltake Toughpower 750Watt PSU
    I don’t have any third party plugins installed, because I just did a fresh install.
    Any suggestions? 🙂
  • Jordan Orberg
    October 25, 2007 at 12:47 pm
    Okay — now Adobe Media Encoder works, but it won’t render out my imbedded After Effects Composition. If I go to File/Export/Movie and just export an .AVI, the After Effects comp shows fine. However, when I use the media encoder, it simply shows the color bars where my After Effects Composition was.
    (For some weird reason, to get Adobe Media Encoder working, I created a blank project and added some black video. I then clicked File/Export/Adobe Media Encoder, and my computer thought about it for a good 2 minutes — then it loaded up. I closed the blank project and opened my project and the media encoder works fine now)
  • Tim Kolb
    October 25, 2007 at 2:33 pm
    This is the release version?
    When Blast said a “system” reinstall…I’m sure he meant Windows itself…if he didn’t mean that, I’ll suggest it.
    This isn’t something I’ve heard anywhere else…not that CS3 is perfection, but I’ve seen no issues specifically getting Media Encoder to run.
    The Dynamic Linked AE comp is an interesting issue. I don’t see a reason in your system why it would be an issue, but I’m not sure how the display card affects this. I don’t think I’ve had occasion to use a DL comp through the encoder yet, I’ll try to repro it today.
    TimK,
    Director, Consultant
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Mike Velte
    October 25, 2007 at 2:37 pm
    Try updating to Windows Media Player 11 and the latest QT player.
  • Eric Addison
    October 25, 2007 at 4:39 pm
    Are you using Dynamic Link, and that is where the color bars are coming up?
    —Eric
  • Blast1
    October 25, 2007 at 10:29 pm
    [Tim Kolb] “When Blast said a “system” reinstall…I’m sure he meant Windows itself…”
    Thatsa exactly what I meant, if a reinstall of the app didn’t work out too good then a clean install, also prior to install check for BIOS updates, firmware updates, driver updates, etc.
  • Jordan Orberg
    October 26, 2007 at 3:12 pm
    I think that I’m using Dynamic Link – forgive me but I am relatively new to the features in CS3. While in Premiere CS3, I created a new After Effects Composition and it launched after effects, and automatically put the comp into my timeline in Premiere. However, when rendering the video with the Adobe Media Encoder, the composition does not show up. It simply shows the color bars except in black & white.
    I’ve tried exporting all different kinds of ways in the Media Encoder, FLV, Mov, and Mpeg. None of them render out the composition. I’ve upgraded to the latest quicktime and the latest windows media player and still nothing.
    To get the movie to render, I went into After Effects and rendered out the comp that was created and placed that into my PProCS3 timeline instead of the After Effects Composition. This is just a workaround though. Premiere Pro CS3 should render my composition and I shouldn’t have to render out the composition first right?
    I’m really wondering what’s going on. I was kind of looking forward to being able to import comps into PPro and not worry about rendering out secondary videos for my timeline in Premiere. Does anyone have a solution?
    Thanks for everybody’s help so far!
  • Eric Addison
    October 29, 2007 at 3:53 pm
    It’s done that to me, but only when the I’ve moved files that are used in the AE project.
    When Premiere goes to render out your movie file, it builds the movie from all the clips and elements in the timeline, and when it reaches the dynamic link clip, it looks to where all the files are used in that AE comp to build that clip. If one, or more, of those files are unable to be located, you get the color bars.
    Are you using an external drive that contains parts, or all, of your AE comp? Try putting your AE project file, and all the files used in it, on the same drive as your Premiere project file. That should fix the problem.
    —Eric
