Activity › Forums › Adobe Premiere Pro › PPRO? What are youing doing and why?
  • PPRO? What are youing doing and why?
    Posted by Greg Burke on June 18, 2012 at 7:07 am
    Hey All so When I try to playback certain sequences PPRO does nothing…I hit play….the screen just stays on frame and nothing happens? what is this? I need to watch these before export but PPRO is not letting me.
    I wear many hats.
    http://www.gregburkepost.com
    Greg Burke replied 14 years, 3 months ago 2 Members · 4 Replies
  • Mike Molenda
    June 18, 2012 at 6:47 pm
    Try saving, then restarting Premiere and/or your system.
    Out of curiosity, what kind of footage and disk are you using?
  • Greg Burke
    June 18, 2012 at 7:07 pm
    I use a mix, (I know its bad) h.264, MTS, and MP4
    I wear many hats.
  • Mike Molenda
    June 18, 2012 at 7:24 pm
    That’s not too bad, it’s the sort of thing Premiere is pretty much built for. I just ask because I occasionally have the same problem with files running off a G-RAID RAID0 connected over eSATA. I’ve had this problem with AVCHD footage in Premiere, and a similar problem with HDV in FCP7, where it will play back audio, but loop the same five or six frames of video over and over.
    Haven’t had this happen with footage on an internal drive, or a drive connected through FireWire. And it only seems to be one specific drive. I’ve got other G-RAIDs that work fine. So my thought was that maybe it’s the disk.
    Anyway, a simple restart of the software fixes the problem for me every time. Did it work for you?
  • Greg Burke
    June 18, 2012 at 7:28 pm
    ya know its happens so often, it would be a pain, everything’s on my internal RAID drives, its when I import the mp4s that it happens the most
    I wear many hats.
