Activity › Forums › Blackmagic Design › PPro3.0 and Decklink 6.6.4 – DV capture
  • PPro3.0 and Decklink 6.6.4 – DV capture
    Posted by Christopher Tay on March 25, 2008 at 7:28 am
    I’m running PPro3.0 and Decklink 6.6.4 driver in a Blackmagic DV project. I’m capturing from a BetaSP VTR via RS422 and when it hits the OUT point, instead of stopping the recording, the VTR continues to play and the Capture window sorta freezes up and you can’t stop the capture. At this point you would think the app has locked up but if you leave it alone, at some point it will stop the capture and everything resumes back to normal.
    I tried again with an uncompressed 8bit project and it doesn’t have this problem.
    Anyone experienced this ?
    -chrispy
    Christopher Tay replied 18 years, 6 months ago 1 Member · 2 Replies
  • Christopher Tay
    March 25, 2008 at 8:11 am
    Forgot to add that if I do a manual capture, it is ok but the moment I use IN/OUT to capture, the problem will show up.
    Again, I am capturing to DV format from the Decklink card where this problem shows up. If I capture as uncompressed 8bit format, I don’t have this problem.
    I’ve just tried downgrading to 6.6.2 driver and still no good.
    -chrispy
  • Christopher Tay
    March 25, 2008 at 8:50 am
    I’ve updated PPro to 3.1.1 and problem still there. The problem is that it takes very long to finish the capture in DV format after it go past the OUT point. It can be as long as 30 secs before the window appears for you to name the clip.
    -chrispy
