Activity Forums Adobe Premiere Pro PPro shortcuts not working
  • PPro shortcuts not working
    Posted by Jourdan Gaub on May 29, 2009 at 5:04 am
    Hi I have been using adobe products for 4 years now and I can’t figure this one out. The go to next edit point and go to previous edit point shortcuts are not working. In the keyboard shortcuts settings they are set to pg up and pg down respectively. But when I try to use them in the timeline nothing happens. I have also tried setting them to different keys and still nothing. I am using Adobe Premiere Pro v4.0.1.
    Please help
    Jourdan Gaub
    Jeremy Mayhew replied 14 years, 6 months ago 3 Members · 2 Replies
  • Eddie Lotter
    May 29, 2009 at 1:49 pm
    That is strange indeed. You can try renaming your preferences file to see if it helps.
    Also try the 4.1 update.
    Cheers
    Eddie
  • Jeremy Mayhew
    March 12, 2012 at 10:31 pm
    I’m having the exact same problem and I’m using Premiere CS5.5. Can’t figure this out for the life of me. Same problem occurs, even if I switch to FCP shortcut settings.
