Activity Forums Adobe Premiere Pro PPro RED SCREEN .mxf files
  • PPro RED SCREEN .mxf files
    Posted by Austin Eschenbach on November 28, 2011 at 4:05 pm
    Hi all. New to the forums.
    I’m having playback issues with Premiere Pro. I recently got independently shot footage from a Sony XDCam HD 35 in .mxf files, and during playback in PPro I get super lag (15-30sec after hitting play to play), and when it doesn’t lag the footage plays normally then cuts out to a RED SCREEN.
    Not sure what to do about this; I’ve been forum surfing and have tried
    – importing from media bay as opposed to using CMD+I
    – copying files to hard drive vs. running from the external the footage came from
    – cutting down preview and playback resolutions
    – experimented with different sequence presets
    The files I’m working with range from 100MB to 1GB (minus the audio) and my computer specs are as follows:
    27inch iMac
    Mac OS X 10.7.2
    2.93 GHz Intel Core i7
    4 GB 1333 MHz DDR3 RAM
    ATI Radeon HD 5750 1024 MB
    And the files I’m working with are as follows:
    MXF (OP-1a) (XDCAM HD 25)
    35.0 Mbps, 1440*1080 (16:9), at 29.970 fps, MPEG Video (Component) (Version w) (Main@High) (CustomMAtrix / BVOP) (XDcAM HD 35)
    Any help will be much appreciated
    James Kumorek replied 13 years, 3 months ago 2 Members · 1 Reply
  • James Kumorek
    May 9, 2013 at 9:37 am
    Did you discover a solution to your problem? I’m having the same issue with Premiere CS6 and footage from a C100 camera.
