Activity Forums Adobe Premiere Pro PPro playback issues
  • PPro playback issues
    Posted by George Loch on December 19, 2011 at 8:12 pm
    So, I have found that PPro 5.5 will not playback a sequence at times and I am trying to figure out why. I have a MacPro 8-core 2.4 system with 8 gigs of ram. When I open the sequence and hit play, the play button changes to the stop button but the sequence doesn’t play.
    Is there a known issue with this on the mac?
    -gl
    twitter: @georgeloch
    web: https://georgeloch.com
    George Loch replied 14 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Petros Kolyvas
    December 19, 2011 at 9:28 pm
    Are you using any monitoring hardware?
    With previous Matrox drivers I found this to be the case quite frequently.
    There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger
  • George Loch
    December 19, 2011 at 9:34 pm
    Actually, it’s all software monitoring.
    -gl
  • Petros Kolyvas
    December 19, 2011 at 9:46 pm
    Well, I guess the usual “more details” questions apply (forgive me if I’m asking you to repeat yourself.)
    – What is your sequence setting?
    – What are are the media formats?
    – Are you running the latest PPro? (5.5.2)
    – Does it happen with all sequences?
  • George Loch
    December 19, 2011 at 9:51 pm
    I am suspecting some kind of incompatibility. I restarted the machine and the sequences played back fine.
    The footage came from the Panasonic HMC80. The sequence settings are at 24p/48Khz 1280×720
    It is 5.5.2
    It was happening with whatever project I opened.
    -gl
  • Tom Daigon
    December 20, 2011 at 12:45 am
    Try going into Prefs / Media and then activate Clean.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Darin Griffith
    December 21, 2011 at 3:20 pm
    George,
    You may want to see my post on playback woes I posted just a few minutes ago. I am running a Mac Pro with CS5.5 and have had similar issues.
  • George Loch
    December 21, 2011 at 6:24 pm
    That seems to resolve the problem. I just wonder what causes it. Thanks!
    -gl
