Activity › Forums › Adobe Premiere Pro › PPro needs to render with native footage?
Posted by Christopher Targia on July 23, 2015 at 6:40 pmI have footage that I am trying to use in PPro CC 2015, and when I put everything in a sequence, I had selected match settings to the footage, and yet it is still making me render the files. Is this normal or am I doing something wrong?
I am a recent convert from FCP 7, it is nice how PPro reads everything no problem, but I find it really strange I would need to render footage that matches the sequence.
Any help appreciated.================================================
MacPro 4,1 Dual Quad-Core Intel 2.26Ghz, 16GB DDR3 Ram
FCP 7.0.3
-I highly recommend el Gato Turbo264HD-Morten replied 11 years, 2 months ago 4 Members · 7 Replies -
Ann Bens
July 23, 2015 at 6:43 pmMatch sequence settings as in right click on clip in Project Window/Make sequence from clip?
What color is the bar above your footage?https://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-green-render-bars.html
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional -
Christopher Targia
July 23, 2015 at 6:55 pmI meant to include this picture in the OP
It is yellow
Turns green after render, I have an hour and a half of footage, so if there is a way I can avoid this, that would be great.
I can work with the footage and play it back, but I need to output the raw to my producer, so I assume I need to render it first?
FCP 7.0.3
-I highly recommend el Gato Turbo264HD- -
Alex Udell
July 23, 2015 at 7:07 pmHey Chris…
bars don’t mean the same thing as FCP….
no bar means no problem
Yellow means probably can play back no problem
Red – likely to drop frames, rendering recommended
Green – Preview file has been rendered
hth,
Alex Udell
Editing, Motion Graphics, and Visual FX -
Christopher Targia
July 23, 2015 at 7:40 pmIt did play back, but I still was able to render, does that mean the render was unnecessary? Also I am going to export the file now and when I select match sequence settings, it shows a .mpeg file. The original footage was .mov, shouldn’t the sequence be as well? Did I do something wrong here?
FCP 7.0.3
Christopher Targia
July 23, 2015 at 7:51 pmI am also noticing this takes an extremely long time to output files, in FCP, I could export reference files, which would take not much time at all, then compress H.264 files with el gato Turbo.264 HD which was much faster then this. I just want to output a low quality sample.
FCP 7.0.3
Alex Udell
July 23, 2015 at 8:37 pmBecause FCP was based pretty much around the homogenous codec of Prores…
ref files could be done with pointer files which happen quickly…
PPro can do this with some formats (including ProRes and XDcam) which they call “smart rendering”
so it depends on your source if this possible…
this might help:
Alex Udell
Morten
July 25, 2015 at 8:46 amRender is not necessary most of the time, however you can set in and out points on the timeline and select to render partially. The render format is defined in the timeline settings. It’s a good idea to set it to the same format as the wanted output – as premiere will allow you to reuse the renders open outputting.
– No Parking Production –
Adobe CC2014, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8
