Activity Forums Adobe Premiere Pro PPro exports MXF DV25 PAL codec progressive?
  • PPro exports MXF DV25 PAL codec progressive?
    Posted by Dirk Dejonghe on December 6, 2011 at 3:55 pm
    I have a job going on where I will need to export about 25 hours of material at the end.
    It is captured in Prores 4:2:2 8 bit interlaced PAL (720×576).
    We need to deliver in Avid MXF DV25 PAL codec but progressive. I can’t see any option in AME to do DV25 PAL codec in progressive, only interlaced.
    Any suggestions to tackle this problem?
    Dirk
    http://www.postproduction.be
    Dirk Dejonghe replied 14 years, 9 months ago 2 Members · 2 Replies
  • John-michael Seng-wheeler
    December 7, 2011 at 2:40 am
    I’m assuming you’re using the AVID codecs installed into Quicktime correct?
    I just checked the AVID DV codec and inside “codec options” you can select progressive or interlaced.
  • Dirk Dejonghe
    December 7, 2011 at 6:05 am
    Maybe I need to reinstall Avid codec after updating to PP 5.5.2? I have no choice to do progressive as it is now, will investigate.
    Dirk
