Activity Forums Adobe Premiere Pro PPro Export P2 AVCIntra-100
  • PPro Export P2 AVCIntra-100
    Posted by Ed Mohar on July 16, 2012 at 2:23 pm
    Hello,
    I have some P2 media cut up in PPro, and I’m tryign to get that back into avid. I thought the easiest thing would be to export a P2 structure in AVCIntra100 that I could simply AMA to in Avid…
    But when I export it from PPro, Avid cannot AMA to it. I then tried to load the structure into the P2 Viewer as a virtual volume, and it didn’t see any clips!
    The folder is 5GB so there is data there — Adobe can load it back up, but nothing else can…
    Am I missing something? Or is this workflow just incompatable– should I be trying something else?
    -Ed Mohar
    John-michael Seng-wheeler replied 14 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    July 16, 2012 at 5:59 pm
    Adobe Premiere does this? Exports to a P2 volume structure?
    Shane
    Little Frog Post
  • Shawn Miller
    July 16, 2012 at 7:22 pm
    Do you have a P2 camera or card reader? I’ve written directly from Premiere to a P2 card via 32bit PCMCIA card reader before. The video worked on the camera and that footage worked on another system, so I’m pretty sure the workflow is solid.
    [Shane Ross]“Adobe Premiere does this? Exports to a P2 volume structure?”
    Yes, it will also output MXF 0P1a in XDCAM, IMX and DV25.
    Shawn
  • Ed Mohar
    July 16, 2012 at 7:30 pm
    I hadn’t tried exporting directly to a card. I had exported to a folder, and loaded the folder as a virtual volume in panadonics P2 Viewer utility and it didn’t identify any clips.
    -Ed Mohar
  • Chris Tompkins
    July 16, 2012 at 7:38 pm
    Yes AME export to P2 Format.
    We have been mastering finished programs to P2 with the Adobe Suite.
    Chris Tompkins
    Video Atlanta LLC
  • Shawn Miller
    July 16, 2012 at 7:45 pm
    [Ed Mohar] “I hadn’t tried exporting directly to a card. I had exported to a folder, and loaded the folder as a virtual volume in panadonics P2 Viewer utility and it didn’t identify any clips.”
    Odd, I haven’t tried using P2 viewer to browse exported P2 folders… can you play the clips directly in Windows Explorer or the Mac Finder?
    Shawn
  • Ed Mohar
    July 16, 2012 at 11:08 pm
    Yes.
    -Ed Mohar
  • John-michael Seng-wheeler
    July 17, 2012 at 7:02 pm
    Have you tried exporting the AVCIntra in an MFX 0P1a instead?
