Activity › Forums › Adobe Premiere Pro › PPro CS6 doesn’t Quit normally! Unexpectedly Quits everytime.
Posted by Matt Campbell on April 18, 2013 at 3:02 pmEvery time I quit the App, it doesn’t quit normally like it should. I get the unexpectedly quits message. The app then looks like its running in Finder (or App Switcher, Command Tab) and I’ll have to Force Quit, where it says application not responding.
Anyone else had this issue? Or know how to solve it?
OSX 10.7.5 with a 3.39 Ghz Intel Core i7 on a built up Hackintosh
16 GB of RAM with OSX on SSD, (2) internal HDDs RAID’d 1 for project files and External RAID 5 for all project assets (media, GFX, stills, etc.)Roberto Serrini replied 11 years, 5 months ago 9 Members · 29 Replies -
Gary Milligan
April 18, 2013 at 3:37 pmHave you tried using Disk Utility to repair permissions? I can’t say for sure that this will make a difference but that would be my first step. If that doesn’t work, rebuilding your directory using Disk Warrior might help. It could also be a Hackintosh issue. Good luck.
Gary
Matt Campbell
April 18, 2013 at 3:56 pmThanks. I’ll try the permissions. I’ve had nothing but issues with the Hackintosh. But unfortunately its not my call. I’m trying to get a new tower! Fingers crossed.
16 GB of RAM with OSX on SSD, (2) internal HDDs RAID’d 1 for project files and External RAID 5 for all project assets (media, GFX, stills, etc.) -
Tim Kolb
April 18, 2013 at 5:03 pmHmmm…”Hackintosh”…just the word has more adventure than I’m interested in…
If it was Windows, I’d start by asking about any networked printers…but Mac OS is pretty self-contained that way I assume.
TimK,
Director, Consultant
Kolb Productions,Adobe Certified Instructor
Alex Udell
April 18, 2013 at 7:45 pmWell if it happens every time….it’s not exactly “Unexpected”
ba-dump-dum-crash
thanks….I’ll be here all week…tip your waitresses…
sorry I could not resist…
Alex
Erik Mickelson
April 18, 2013 at 8:06 pmWhy don’t you first remove the “overclock” on the i7 and get back to us?
CrippleBook Pro 2.3Ghz i7, 16GB ram, Lion 10.7.4, FCPStudio 3, Adobe CS6. QT 7
Matt Campbell
April 18, 2013 at 8:17 pmuhhhh, what? Have no idea what that is or how to do it. Believe me, this isn’t the first time something hasn’t agreed with this Hackintosh crap.
Erik Mickelson
April 18, 2013 at 8:26 pmMaybe “Hacks” are not for you this time around. They require a diligent setup, then they work flawlessly. What exactly is the Hack setup? Motherboard, chipset, bios version….just get a “real” Mac.
Go to Tonymac and do some research, you can probably fix it.
Matt Campbell
April 18, 2013 at 8:38 pmUnfortunately it wasn’t up to me or I’d already be on a MAC Pro. They built 2 Hacks for the price of 1 tower, to try and save money. These were built back before I started, so I was dealt these cards. I’d rather spend the $ upfront, then spend the time later fixing problems. Other than whats in the system profiler (below), I have no idea what specs are used.
Although I do know the GFX card is: AMD Radeon HD 6870
Which says isn’t supported by Premiere, but read others have used it and had no problems. Maybe this is it. But would think not, because I used PProCS6 to just cut about 6 videos. Import 7D footage, edit, export to ProRes, all with no issues. Only when I Quit.OSX 10.7.5 with a 3.39 Ghz Intel Core i7 on a built up Hackintosh
Erik Mickelson
April 18, 2013 at 8:51 pmThat info really does not tell anything. It shows what YOU told the computer to look like for OSX. The actual hardware would be in the bios.
You can try changing the Model ID to an iMac, sometimes that lets OSX have better access to updated “drivers”. MacPro is an old Machine ID and does not have USB3 or any of the other new technologies.
Running an internal Raid 1 on a hack. That might be the problem right there. But maybe not. External Raid 5, maybe the card is not behaving? Why not take this discussion to a site that deals with Hacks specifically?
Also, 10.8 Mountain Lion has direct support for i7 chips, USB3 etc…just sayin’. You would need to do a new vanilla install.
Matt Campbell
April 18, 2013 at 8:53 pmThanks Erik, will do. All this is beyond my scope of knowledge. I’ll stick to editing. Appreciate the help. Thanks.
