Activity › Forums › Blackmagic Design › PPro CS6 and Decklink Studio 2 with 9.5 drivers
Kim Wang replied 14 years, 1 month ago 5 Members · 23 Replies
Kim Wang
July 4, 2012 at 2:52 pmI have the same problem with intensity pro. No video out with 720P sequence. But 1080p sequence work fine.
Window 7
GTX 470
24G RAM
Premiere pro CS 6.0.1
intensity proBMD’s Desktop Video 9.5.3 for Windows.
Called BMD. The support told me I cannot have CS5.5 & CS6 on the same machine. I should get a new pc and install CS6 only. He explain their installer looks for the first PP they find and install it there. I asked if I can manually copy the plugin to the proper folder. He replay “no. just gets a new PC. “ I have amazing experience with BMD before. He must be having a bad day. I also ask if a fix is coming. He relay “No”.I think its bug, hopefully it get fixed soon.
BTW work fine on After effect CS 6.
Kim W
James Orlowski
July 5, 2012 at 12:20 pmMake sure your 720p projects are 59.94fps and not 29.97. For some reason, BMD disabled video output on a 720p timeline that’s not 59.94.
It used to work in previous versions.
Kim Wang
July 5, 2012 at 12:41 pmThanks, That worked. By going to the advance tap I changed it to 720p 59.94fps 🙂
regards
Kim W
