Activity › Forums › Blackmagic Design › PPro CS6 and Decklink Studio 2 with 9.5 drivers
Kim Wang replied 14 years, 1 month ago 5 Members · 23 Replies
James Orlowski
May 14, 2012 at 2:22 pmAlso, this problem doesn’t occur in After Effects. Only Premiere.
James Orlowski
RYNO Production, Inc.
http://www.rynoproduction.com
800-860-7966 -
James Orlowski
May 22, 2012 at 5:19 pmJust got off the phone with Blackmagic tech support. They didn’t seem to be aware of this problem, but at least now they are after talking to me.
4×3 SD probably just isn’t a priority for them, but it seems a fix should be simple if they just “write in” a compensation “stretch” value for the outputs.
BTW, this problem doesn’t happen in After Effects, so that’s my work around should I need to output to BetaCam SP.
James Orlowski
800-860-7966 -
James Orlowski
May 22, 2012 at 5:36 pmUPDATE: Blackmagic got back to me and said this problem is being worked on.
James Orlowski
800-860-7966 -
Alan Peil
May 23, 2012 at 2:16 pmThat’s great news! I’ve been going back to PPro 5.5 whenever I need to roll to beta.
James Orlowski
May 29, 2012 at 3:05 pmLooks like driver 9.5.2 solved this problem.
James Orlowski
800-860-7966 -
Jeff Anderson
June 5, 2012 at 2:41 pmProblem solved! Since I’ve updated to Blackmagic v9.5.2 driver CS6 will now playback SD video correctly.
Jeff Anderson
Alan Peil
June 20, 2012 at 4:54 pm9.5.2 Fixed the “squeezed video/green static issue”, but I still can’t get a 720p 29.97fps sequence to output to my monitor…any word on a fix for that issue?
James Orlowski
June 20, 2012 at 4:55 pmI suspect they dropped outputting 720 29.97fps since the “standard” is 720 at 59.94fps.
I simply just make a 59.94 timeline even tho all my footage is 29.97 and my exports are 29.97. Works fine.
