PPro CS5 Pentax K7 footage export problem
Hello,
I’ve edited a video in PPro CS5 with footage from a Pentax K-7 HD DSLR. I dont have a lot of experience with HD DSLR footage, but I have worked with 7D footage with no problems at all.
The problem I am having is that when I export the video using H.264 everything looks great on my Mac Book Pro. When I upload it to Vimeo and watch it it still looks great, and it looks fine when I play it on my Iphone 3GS through the Vimeo app., but every other computer Ive watched it on or had co workers watch it on there are strange glitches that are very obvious. It looks like horizontal bars, not like you would see with interlaced footage, but horizontal bars that look like the shot is arranged incorrectly or something to that effect and it increases as motion increases.
I have made several time lines with different properties, and exported each of them out a few different ways. Only two of the options show up fine for me no matter how I view the footage, unless its on another computer. The rest are bad for me and everyone else
Just to put it out there, I know it is not an internet connection problem.
Here are the footage settings:
AVI
1280 X 720 (1.0)
30fps
progressive
1m20s
32000 HZ
StereoThese are the source/ outputs that have been successful for me to view on web, hard drive, and Iphone but not for anyone else at all.
Source:
used preset under DSLR heading for 720p 601280X720
59.94 fps
progressive
1m20s
48000HZ
stereoOutput:
NTSC
1280X720
29.97fps
progressive
AAC
192kbps
48KHz
stereo
VBR 2 pass
Target 6.00
Max 10.00 Mbpsthe following setting are the first settings i used with successful viewing on my end
Source: just set timeline using HDV 720p 30fps preset
1280X720
29.97 fps
progressive
1m20s
48000HZ
stereoOutput:
NTSC
1280X720
29.97fps
progressive
AAC
192kbps
48KHz
stereo
VBR 1 pass
Target 6.00
Max 10.00 Mbpsrender at Max depth and Max render quality checked for every attempt
have also tried timeline settings to match footage but when i went to export footage it went to export for Iphone…
I have Production Premium CS5
my scratch disks are set to my external HDI use a Macbook Pro
Model Name: MacBook Pro
Model Identifier: MacBookPro8,2
Processor Name: Intel Core i7
Processor Speed: 2 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Memory: 4 GB
Boot ROM Version: MBP81.0047.B1E
SMC Version (system): 1.69f1
Serial Number (system): C02FFLB6DF8V
Hardware UUID: AAD68C33-11C8-5F01-BF34-5694A2EC0E3E
Sudden Motion Sensor:
State: EnabledThanks a lot!!! Ive tried to give all the info I can think of.
i dont understand why I can see fine and others cant.Here is a link and a pass to view the video on VIMEO
https://www.vimeo.com/30146396
Pass: smooth
Thank you
Nathan
