Activity › Forums › Adobe Premiere Pro › PPro CS3 & FX1700
  • PPro CS3 & FX1700
    Posted by Michael Mohr on January 21, 2008 at 5:54 pm
    Is anyone out there using a PNY Nvidia Quadro FX 1700 or 1500 to monitor there video on an NTSC monitor? If so, can you help me with the setting to get the video onto the monitor? PNY has been as helpful as they can be.
    Michael Mohr replied 18 years, 8 months ago 2 Members · 2 Replies
  • Mike Velte
    January 22, 2008 at 2:26 pm
    You will need a firewire output to a A/D converter (or DV camcorder) and from there to your TV via analog cables to preview Premiere’s timeline.
    https://www.video2stream.com
  • Michael Mohr
    January 23, 2008 at 2:17 pm
    Thanks for the info. I was hoping to use the FX1700 break out box but seeing I’m havinbg so much trouble with the configuration I used your method. All I had to do is figure out how to pass audio via firewire and bingo. This should work out much better.
