Activity Forums Adobe Premiere Pro PPro CS3 deinterlacing – does it still drop vertical res by 50%?
  • PPro CS3 deinterlacing – does it still drop vertical res by 50%?
    Posted by Jack Kelly on July 13, 2007 at 11:58 am
    Hi there,
    As we all know, CS3 includes a cool new time-remapping feature. The presence of this new feature might suggest that PPro CS3’s handling of interlaced video has been improved. So my question is: does CS3 now include an “intelligent” de-interlacing system which uses motion compensation to interpolate the missing vertical resolution (like many of the de-interlace filters used in aviSynth)? Or does de-interlacing in PPro CS3 still halve your vertical resolution?
    Many thanks,
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
    Jack-Kelly.com – my homepage
    Blast1 replied 19 years, 2 months ago 5 Members · 15 Replies
  • 15 Replies
  • Tim Kolb
    July 13, 2007 at 1:23 pm
    Hi Jack,
    Deinterlacing on speed changes (slo mo, time remap) is now the same as AE…which is far better than what PPro had before…which was not very good.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Blast1
    July 13, 2007 at 7:08 pm
    Hi Tim:
    Do you know how the deinterlacing now compares to something like the deinterlacer that comes with Resizer?
  • Jack Kelly
    July 13, 2007 at 7:18 pm
    Hi Blast1,
    If I may be so bold, I’d like to jump in here.
    In terms of comparing PPro’s de-interlacing with other systems, I’ve just spent the day comparing PPro 2.0’s de-interlacing with aviSynth’s de-interlacing:
    https://www.dvinfo.net/conf/showthread.php?p=711674#post711674
    Jack Kelly
    London
    Dir / Prod / Camera
  • Blast1
    July 13, 2007 at 7:54 pm
    Thanks for the info, interesting about the p project, I’m more concerned in de-interlacing DV WS prior to upscaling for use in HDV projects.
  • Tim Kolb
    July 14, 2007 at 5:17 am
    One would need to compare CS3 and Resizer I suppose, PPro CS2 is simply not as good.
    I use Instant HD occasionally…but I’ve done no specific testing on it.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
  • Marcus Van bavel
    July 14, 2007 at 2:03 pm
    You might look at DVFilm Maker which can
    1) deinterlace intelligently and also
    2) smooth the 4:1:1 chroma to 4:4:4
    3) enlarge to 1440 x 1080 anamorphic
    in one step. It can also batch process clips.
    Here is a comparison test between conventional
    editing system deinterlacing and DVFilm Maker
    https://dvfilm.com/maker/MakerVegas.htm
  • Blast1
    July 14, 2007 at 10:01 pm
    [Tim Kolb] “compare CS3 and Resizer”
    Thats what I was wondering if someone had done, I’ve seen a comparison between Instand HD and Resizer1 with footage deinterlaced in AFX, they were fairly close, since Resizer 2 is shipping with its own deinterlacer I was curious if the one in CS3 was as good.
  • Blast1
    July 14, 2007 at 10:02 pm
    Hi Marcus
    Thanx for the info, but I didn’t see anything about 30p or 60p just 24p, I was more interested in video vice film
  • Marcus Van bavel
    July 15, 2007 at 2:53 am
    Maker does 60i to 30P as well as 24P.
  • Jonathan Shohet
    July 17, 2007 at 9:50 am
    Has anybody had any experience with the Alparysoft deinterlace filter plug-in for premiere?
