Activity Forums Adobe Premiere Pro ppro cs3 conforming audio issue
  • ppro cs3 conforming audio issue
    Posted by Scott Cary on December 30, 2008 at 10:41 pm
    Ive captured about 14 tapes in native hdv into pro cs3. everything is fine except for one clip. every time I drag it into the source window
    it plays erratically and in the very lower left hand corner of the workspace there is a blue bar stuck half way and it says “conforming tape 1.mpeg” it never changes no matter if I reboot or not. did i loose an accompanying file somewhere and it is searching?
    Scott Cary replied 17 years, 7 months ago 2 Members · 4 Replies
  • Eddie Lotter
    December 30, 2008 at 10:57 pm
    Have you applied the CS3 updates?
    Cheers
    Eddie
  • Scott Cary
    December 30, 2008 at 11:21 pm
    yes, i did that recently because audio was not synching. but that is fine now. looks like it is something else
    thanks
  • Eddie Lotter
    December 31, 2008 at 2:24 pm
    My last suggestion is Deleting your MPEG index and conformed audio files. Sorry.
    Cheers
    Eddie
  • Scott Cary
    January 6, 2009 at 5:30 pm
    Sorry for the delayed response. Thanks Eddie. I found several folders with the MACC extension that pertain to my project and there are many
    mpeg index files in them. However there are also many pek files and cfa files. Do you know if I should delete them as well or just pin point the old mpeg index files?
    Thanks again
    Scott
