Activity › Forums › Adobe Premiere Pro › PPro CS3 – capturing 4 audio channels from Sony J-30
  • PPro CS3 – capturing 4 audio channels from Sony J-30
    Posted by Antonio Flores on March 31, 2008 at 3:10 pm
    Hi all,
    I’m trying to capture audio channels 1-2 and 3-4 from 25 Digibeta tapes through a Sony J-30 SDI player.
    Adobe Premiere Pro CS3 being a professional editing tool, I’m hoping this is possible to do.
    I’m capturing using Firewire connection and I have selected in the Sony player setup menu to output all 4 channels – so my problem is to figure out how make premiere capture 4 channels at the same time.
    Help much appreciated.
    Antonio Flores replied 18 years, 6 months ago 1 Member · 1 Reply
  • Antonio Flores
    April 3, 2008 at 2:57 pm
    Its possible to do it in a 2-pass process, capturing first the CH1/2 and than CH3/4, but this method its a pain when I want to capture 25 tapes or more.
    In the User Manual of the player says:
    Menu 831 – i.LINK AUDIO OUTPUT SELECT (Selects audio channels output from the iDV connector):
    OPTION 1) CH1/2: Outputs audio signals (16 bits/48K) recorded in CH-1/2.
    OPTION 2) CH3/4: Outputs audio signals (16 bits/48K) recorded in CH-3/4.
    OPTION 3) CH1/2/3/4: Outputs audio signals (12 bits/32K) recorded in CH-1/2/3/4.
    I have selected OPTION 3).
    So, being possible to select in the player menu to output all 4 channels through FireWire/iLINK, if PPro CS3 doens’t do it, whitch software is able to capture all 4 at the same time? Final Cut? Some other small software?
