Activity Forums Adobe Premiere Pro PPro and Ultra 2 crahing
  • PPro and Ultra 2 crahing
    Posted by Rci124 on January 22, 2006 at 3:48 pm
    I have PPro and I am trying to export a green screen video clip to Ultra 2 and it crashes Ultra all the time. I talked to tech support at Ultra2 and after trying several things and checking setting we have come to the conclusion that I am doing something wrong when exporting the clip from PPro or I am using the wrong codec. PPro is set to Microsoft DV AVI and DV NTSC.
    The clip is 12 min. 22 seconds long. I have tried the clip with and without the green screen keyed out when rendering in Ultra 2. I have turned the GPU boost on and off in Ultra 2 when rendering. It will crash anywhere form 5 seconds to 4 minutes into the clip. The error message is
    Rci124 replied 20 years, 8 months ago 2 Members · 4 Replies
  • Tim Kolb
    January 22, 2006 at 5:29 pm
    Could you please be VERY specific about how you are exporting the clip and setting the output in Ultra?
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Rci124
    January 23, 2006 at 12:16 pm
    I use PPro to capture the clip, render the clip and export it as a movie and it is exported as an avi clip using Microsoft DV AVI and DV NTSC. Then I bring it into Ultra2 key out the green screen and render it out using a DV video Encoder format
    The clip is 12 min. 22 seconds long. I have tried the clip with and without the green screen keyed out. I have turned the GPU boost on and off in Ultra 2 when rendering. It will crash anywhere form 5 seconds to 4 minutes into the clip. The error message is
  • Tim Kolb
    January 23, 2006 at 6:36 pm
    Have you tried a different clip?
    also…have you tried to export a shorter version of the same clip…or simply re-exporting the entire thing? Maybe there is one corrupt frame in there…
    Also../.the drive you are rendering to is not formatted FAT 32 is it? There is a filesize limitation that may be biting you if that’s the case.
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
  • Rci124
    January 24, 2006 at 5:24 pm
    Tim,
    I found the tape I used on this project and recaptured it. So far I haven
