Activity › Forums › Adobe Premiere Pro › PPRo 4.2.1 crash after Quicktime 7.6.5 update
Jon Barrie replied 16 years, 6 months ago 3 Members · 13 Replies
Jon Barrie
February 28, 2010 at 3:28 amTry clearing the preferences of ppro by holding down alt shift ctrl all together while ppro launches. It reloads all plugins fresh and resets the preferences. Don’t let go of the buttons until u see the splash screen where it asks u to make new or open a project.
Otherwise you may have an incompatible update on the graphics card. The newest card drivers aren’t always the happiest with ppro.
I am running win7 64 with QT7.4.5 and don’t upgrade it as it works perfectly. Ain’t broke don’t fix it policy with QT is a must.
– Jon Barrie
Jon Barrie
aJBprods
http://www.jonbarrie.net
http://www.suiteskills.com -
Jon Barrie
February 28, 2010 at 6:00 amI scrub plenty. Animation Codec is preferred by most editors as a lossless quality codec.
I’d say that the QT update has screwed up something in the preferences and you may need to uninstall the QT you have, make sure to reboot.
Then install 7.6.5 (I’ve double checked that this is the one I’m running.) Then reboot.
Now launch PPro and hold down the SHIFT+ALT+CTRL keys while it loads all the plugins etc. Wait until you see the New or Open splash window. Let go of the keys.
Start a new project and import the one you have had issues with. Import the entire project and it will import with a folder named the projects name. Open this folder and find the seq you were working on. It should work fine. If not, you’ll have to do a complete reinstall of PPro…
– Jon Barrie 🙂
Jon Barrie
aJBprods
