Activity Forums Adobe Premiere Pro Ppro 2 multicam weirdnessy
  • Ppro 2 multicam weirdnessy
    Posted by Marc Bauwens on January 25, 2006 at 6:20 pm
    I downloaded the tryout version from the Adobe site to give it a test drive.
    So far I can say it has been a pretty pleasant experience, but I stumbled upon an unforeseen and strange problem with the multicam feature.
    When I go into record mode in the multicam window and press play, the individual windows start crawling over the multicam monitor space and the playback just stalls. When I scrub I can see the frames nicely, but can not cut realtime.
    THe project I used to test is a Blacmagic YUV 8 bit project in 4:2:2 with PAL Beta SP sources.
    Any ideas ?
    Marc Bauwens replied 20 years, 7 months ago 2 Members · 2 Replies
  • Aanarav Sareen
    January 25, 2006 at 6:48 pm
    System specs? If your system is slow then you may notice the stuttering.
  • Marc Bauwens
    January 25, 2006 at 7:48 pm
    P4 3.2 G
    2 GB RAM
    A SATA Raid with 2 MAxtor SATA 250 GB discs striped in RAID 0
    But I think I found the problem, raid not fast enough, it seems to drop frames on playback. When I remove the abort on playback checkbox the video plays but stutters insanely…
    I’m going to do a drivetest with the BMD app and will post the results here.
    D#mn…. when will i get out of system hell ?
