Activity Forums Adobe Premiere Pro PPro 2 loses recognition of dv deck randomly
  • PPro 2 loses recognition of dv deck randomly
    Posted by Lance Bauerfeind on May 13, 2006 at 6:53 am
    Hi
    I am running PP2 on XP Pro, 2GB RAM. Intel 3.2, Radeon XT9600 graphics
    with a DSR-11.
    The problem is premiere will randomly fail to recognise the deck and shows it as offline even though 5 min before I had captured something. I have tried using another dsr 11, using another pc with ppro 2, no luck.
    So, I have tried different decks, different pc’s (therefore different cables), even different versions ( one is an upgrade the other a full version. Tried restarts, complete shutdown and no joy. I can come back the next day and everything is fine and working normally.
    Any suggestions?
    Cheers
    Aanarav Sareen replied 20 years, 4 months ago 4 Members · 9 Replies
  • 9 Replies
  • Aanarav Sareen
    May 13, 2006 at 7:56 am
    Download a software called ScLive from https://www.scenalyzer.com and try capturing via that app. Does the same thing happen?
  • Lance Bauerfeind
    May 13, 2006 at 10:59 am
    thanks for your reply Aanarav. It will be a couple of days until I’m back at work. I will reply once I have done the test.
  • Richard Evans
    May 14, 2006 at 2:19 pm
    I’ve had my PC lose recognition of my DSR-11 if I plug another firewire device to my computer. I’m not sure if that’s normal, but it happens. Maybe you had a conflict of some sort.
    Richard
  • Lance Bauerfeind
    May 15, 2006 at 4:31 am
    I have no other firewire device attached so I don’t think it is that.
    The thing is, which I forgot to mention, is that I have no problems with 1.5. I use my dsr to preview out to monitor. PPro 2.0 doesn’t work 1.5 does.
    i also have just read on dv.com a review by John Jackman of the production bundle and he mentions having the same problem when he was capturing off his JVC Camera.
    Aanarav, I am downloading the capture software today and will give it a go but if everything works in 1.5 will this help solve the problem.
    I am wondering if it might be a bug.
    Cheers
    Lance
  • Victorypoint
    May 15, 2006 at 5:11 am
    Are you have Decklink drivers or Morgan switch installed?
    -AJ
  • Lance Bauerfeind
    May 15, 2006 at 5:34 am
    No
    I am strictly DV. No capture cards at all or any third party hardware/software just premiere and firwire card.
  • Aanarav Sareen
    May 15, 2006 at 2:21 pm
    Lance,
    It’s not a bug. However, it is a problem with a few systems. Premiere Pro 2.0 broadened the capture criteria, so a lot more hardware based solutions are supported (HDV and the Aja cards) and hence the cause of the problem. There is a solution some place, I just have to look for it 🙂
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Lance Bauerfeind
    May 15, 2006 at 7:51 pm
    Thanks Aanarav – I’ll wait for your reply.
    BTW Tried Scene Analyser and it works fine.
  • Aanarav Sareen
    May 15, 2006 at 10:44 pm
    Here is the solution:
    Download GraphEdit from Videohelp Tools or from anyplace else on the web that you prefer.
    Once you’ve downloaded and installed (should take about 10 seconds), open GraphEdit and choose Graph > Insert Filters. Scroll down to a listing for “Video Capture Sources” and expand it to see what’s there. If you’ve got anything other than Microsoft DV camera and VCR, then expand that entry to see the location and name of the file. Navigate to that location and rename it’s file extension to .old. Now try capturing in PPro 2.
    Courtsey of Mitch411 from the Adobe User to Use forums.
