Activity Forums Blackmagic Design PPro 1.5 sluggish performance
  • PPro 1.5 sluggish performance
    Posted by Jaromir Pesr on October 19, 2005 at 7:10 pm
    I have got BM Deckling HD Pro 444 card (5.2.1 driver) inside dual Xeon 3.6, 2GB machine running PPro 1.5.1. I was using it especially for short projects such as TV commercials or music videos and everything seems to be ok. Now I have captured several longer 10bit 4:2:2 clips (each about 20 minute lenght) from Digibeta deck and was very surprised how slow is PPro performance. When I put any of those clips to timeline I must wait nearly 10 seconds to see a picture in monitor window. Then I can play it quite well (no dropouts) but any manipulation on timeline (just simple cut or even move) repeats this delay. I can scrub on timeline but do not see any picture until I wait these 10 seconds. I have captured those clips with no sound so there is no any audio conforming running on background, and I hope my 4 drive RAID 0 is fast enough.
    Is it PPro known long project behaviour or is there something wrong? I’ve tried to reinstall PPro with no success, there should be issues caused by several BMD drivers reinstallations etc but I’m in a middle of several projects.
    Every post is welcome…
    Jaromir Pesr
    IO postproduction
    Prague, Czech Republic
    Matt Dowling replied 20 years, 11 months ago 6 Members · 8 Replies
  • 8 Replies
  • Myron Lenenski
    October 19, 2005 at 8:51 pm
    We had the same problem. Any clip longer than ten minutes causes a meltdown. If you want longer captures, you enter this area of unexplainable sluggishness.
    We called Decklink and Adobe and nobody knows why or what to change. It sucks.
    We downloaded the Sony Vegas free trial and it works okay on long captures, but that’s not the direction we want to go.
    Email them both directly, this needs to get fixed.
  • Jaromir Pesr
    October 19, 2005 at 10:34 pm
    I’m not sure if it has appeared when I started to work with Deckling. I think I have no problem to work in PPro with long clips long time ago but maybe I’m wrong. I cannot remember what codec was used those days if BMD 10bit or pure uncompressed AVI. Isn’t it some bug in newer drivers? Do you test different ones?
    Jaromir Pesr
    IO postproduction
  • Matt Dowling
    October 20, 2005 at 12:06 am
    We actually reproduced this a couple of days back and have been coding to address it. We will have a fix for this in the next day or so. It looks like this was introduced in 5.2 only.
    Cheers,
    Regards,
    Matt
    Blackmagic Design
  • Jaromir Pesr
    October 20, 2005 at 12:50 am
    Thanks, sounds great…
    Jaromir Pesr
    IO postproduction
  • Tony Partam
    October 20, 2005 at 9:37 am
    Have the same problem here…noticed it really on HD long projects.
    When i used project management and done a copy of the project to a new one in another location with only the clips i used on the timeline the problem dissapeared.
    It is a long clip problem.
    Happy to hear you’re working on it guys.
    Tony
  • Mark Stevenson
    October 20, 2005 at 11:20 am
    Dont know if this helps but i had very bad performance with decklink dual link and even extreme together with premiere pro 1.5.1 until i changed back to version 5.1.1 from 5.2. However i did change the motherboard bios for my supermicro x6dae-g2 from 1.2c back to 1.2a since i have another system that runs fine with 5.1.1 and 1.2a which is how i knew.
    I didnt have the time to check to see what was the problem be it drivers or motherboard but it could be both.
    Finally their was an update to 1.3 for the motherboard but i didnt notice this until after it went on long term loan.
    However i have an issue that i would like people to try under blackmagic DV preset export bars and tone (audio and video) and see if when imported back in it brings the audio back. The reason i ask is becasue all my systems do the same i have tried the latest 5.2.1 driver and that does the same.
    Just in case anyone asks i have ticked the box to say ‘export audio’
    Regards
    John
  • Dkh Lai
    October 21, 2005 at 2:41 am
    I have the export audio problem as well under
    BMD PAL DV project setting.
    Besides, I really hope that the ” Adobe shut down
    problem” can be solve as well for the next driver.
    regards
    Daniel
  • Matt Dowling
    October 22, 2005 at 1:10 am
    Hi Tony,
    We are confident we have fixed this and have also included QT 7 support(about time i hear everyone scream).
    Also the DeckLink is now seen as a sound device by the system, so you can now play audio through the DeckLink across the whole system ie.Windows Media player, iTunes etc…
    We have finished the code and will be posting a beta installer Monday (Australian time)
    Cheers,
    Regards,
    Matt
    Blackmagic Design
