Activity › Forums › Adobe Premiere Pro › pp6 project to pp5.5
  • Angelo Lorenzo
    July 10, 2012 at 5:00 am
    Have them go to File > Export > Final Cut XML. Have them give you the XML file.
    In your version of Premiere, start a new project, right click your bin/library and select “Import…” and import the XML. It’ll probably ask you to locate/relink the files, go ahead and do that and you should be rolling.
    The files and sequences should come in. Most effects and some transitions will not transfer over this way. Adobe, for whatever reason, really locks up Premiere when it comes to working in previous versions.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
