Activity › Forums › Adobe Premiere Pro › PP5.5 very slow on brand new iMac
  • PP5.5 very slow on brand new iMac
    Posted by Brian Car on December 19, 2012 at 4:41 am
    I purchased a brand new 21.5″ iMac late last year.
    Processor 2.8 GHz Intel Core i7
    Memory 12 GB 1333 MHz DDR3
    I installed CS5.5, and found it to be pretty slow. So I got 12GB of RAM. I saw an improvement, but it’s still really slow. Premiere is the worst. When I press play, even on low-res video footage, it takes a few seconds to start playing.
    The worst part: After Effects compositions. I am yet to see one play back at all. I just get the spinning wheel of death whenever I try to play one.
    I have finally had enough of this. Any suggestions? Thanks!
    Tom Daigon replied 13 years, 9 months ago 6 Members · 10 Replies
  • 10 Replies
  • Tero Ahlfors
    December 19, 2012 at 7:26 am
    What footage are you working with and how fast is your storage? Also you can’t really play back footage in AE, use the numpad+0 for a RAM preview.
    We have the 27″ top of the line iMac from last year with a Pegasus RAID and I can easily edit native 4K R3D with 1/2 quality.
  • David Fuku
    December 19, 2012 at 8:27 am
    Yeah your issue is due to:
    1. you have to add the graphic card manually to PP meaning you are probably not using the mercury playback engine.
    2. did you set the ram preference?
    3. you might need a fast scratch disk not the startup disk.
    all basic crap you have to do with any editing software….
  • Walter Biscardi
    December 19, 2012 at 12:41 pm
  • Brian Car
    December 19, 2012 at 3:05 pm
    I was referring to AE comps imported into After Effects.
    The kind of footage varies depending in the project I am working on. It’s usually 720p HD, and I usually have it set to half-res for playback.
  • Brian Car
    December 19, 2012 at 3:07 pm
    I’m poor right now. 😉
  • Tom Daigon
    December 19, 2012 at 3:10 pm
    Even on my powerful HP Z820 I still find that I prefer to render the more complicated AE dynamically linked comps to get smooth playback. You can do that in PrP, but its faster to export a movies from AE since its renders faster then AE. Be sure you check “Project Link”. If you need to make changes to it in PrP, just right click and select “Edit Original” to reopen AE.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Brian Car
    December 19, 2012 at 3:11 pm
    Interesting. How do I manually set a graphics card?
    If you mean “Preferences > Memory,” 9GB are reserved for PP6, and 3GB for other applications.
    Thank you so much!
  • Chris Tompkins
    December 20, 2012 at 1:54 pm
    You didn’t mention what drive(s) your media is playing back from….
    Chris Tompkins
    Video Atlanta LLC
  • Brian Car
    December 22, 2012 at 8:23 am
    Usually the internal harddrive on my iMac. Sometimes from an external harddrive via firewire 800.
    Thanks for the post!
  • Tom Daigon
    December 22, 2012 at 3:03 pm
    Brian, if you plan to edit HD material, your really need a PCIE or USB 3 external raid in order for PrP to function .
    Media should not be on internal or firewire drives for best performance.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
